I want to get educated on encoders suitable for constant bit rate MPEGII TV applications. I have the capture hardware and the link, and a software encoder from captured DV would be fine. I could also spring for the how thing. Telestream was recommend, does anyone know about them?
thanks
Results 1 to 1 of 1
any 64-bit / MultiCore DVD Encoders?
By snadge in forum Video ConversionReplies: 2Last Post: 27th Jun 2010, 19:22 -
How to achieve the maximum bit rate in variable bit rate mode ?
By Sxn in forum Newbie / General discussionsReplies: 42Last Post: 3rd Dec 2009, 13:53 -
[SOLVED!] Converting Variable Sample Rate to Constant Sample Rate
By Midzuki in forum AudioReplies: 17Last Post: 24th May 2009, 11:26 -
Bit Rate And Frame Rate
By bharathi_n_r in forum Video ConversionReplies: 2Last Post: 30th Nov 2007, 06:48 -
the right bit rate
By nojee in forum Video ConversionReplies: 5Last Post: 10th Nov 2007, 04:00
