I'd appreciate some advice on what program will handle this.
I have 15 DVDs, each with about 3 Episodes of a series. For space reasons, I don't want the extras. Each episode also has an introduction in the first chapter of the PGC where the author introduces and discusses the episode. I really dislike that and want it cut off. I just want the episode to start and I want them separated. Currently I do this:
DVDecrypt - select the the PGC for the episode and uncheck the 1st Chapter. I do this for each episode, saving the resulting IFO and VOB to a directory. Then I use AutoGK to convert. The DVDecrypt step of making all the separate selections, running, then coming back 10 minutes later, doing it again, etc. takes a lot of time. The AutoGK step works well because I can set up the jobs as a batch.
Is there a tool that will let me do this in one setup as a batch? It's the unchecking of the first chapter for each job that's the problem. I can't find any way to do that in AutoGK. Will the underlying Virtualdub allow this?
The only way I can think of is to use DVDDecrypter via commandline and setting file-splitting to "by chapter", and then getting rid of (deleting) the file for the first chapter for each ep. However you'd be left with the remaining chapters of each ep as seperate files, so you would have to then find a way to join these before feeding into autogk.
If in doubt, Google it.
AutoGK - XviD to XviD to reduce file size
By marioval in forum Video ConversionReplies: 3Last Post: 16th Jul 2010, 15:37 -
Can I rip a ripped tv series DVD to XviD/DivX ala Fair Use wizard?
By perceptionist in forum DVD RippingReplies: 3Last Post: 2nd Jan 2010, 18:42 -
Good file size when converting TV DVD eps to Xvid/DivX
By ryangarfield in forum DVD RippingReplies: 1Last Post: 28th Apr 2009, 11:06 -
Panasonic DMR-E55-E55S or E55K?1st DVD recorder/1st time posting
By ToeTagged in forum DVD & Blu-ray RecordersReplies: 7Last Post: 19th Jan 2008, 15:33 -
AutoGK dvdrips of TV series producing variable FPS
By honeyko in forum DVD RippingReplies: 0Last Post: 28th Dec 2007, 08:21
