Hey, I've authored a dvd using DVD Lab Pro 2.18 and am burning it using Nero to a Memorex 16x DVD+R Lightscribe DVD at 8x, and have a lot of problems playing it back on a dvd player. I used a multi-PGM title to make the main movie, and each chapter is encoded/demuxed in the exact same way.
It seems that chapters 1-4 of the movie stutter and hiccup occasionally (audio and video) on the dvd player and 5-8 play fine. On WinDVD/MPC, they play fine. I thought maybe it was the stream headers, but when I used DVDLab's "Fix Stream Headers" it said they were fine already.
Theres no audio on WinDVD/dvd player for all of my still menus and one of my motion menus. But, at least 5 of my other motion menus play fine. Even my audio for the compiled DVD (the DVD on the pc, not the one I burned) doesn't work for these menus). I've tried recompiling repeatedly and they dont work. I thought maybe the ac3 files weren't compliant so I used ac3fix but it says its already ok.
The other movie tracks play horribly (bad stuttering/blank video occasionally/blotches).
I have a Set Up menu like this example from DVD-Lab. On the DVD Player, not only will the audio not play because of the problem above but when I start pushing the buttons randomly to test how well they switch menus, it starts bringing up blotches of color occasionally or redirecting me to the wrong menu. On WinDVD/MPC they work fine. The actual mechanism (changing audio and video) work fine.
Changing from the main motion menu to other still menus sometimes produce blotches of pink/miscellaneous colors across the screen when played from the dvd player
I tried playing it on a PS2 and it gives a disc read error.
On Media Player Classic everything play absolutely perfect, both the compiled dvd and burned dvd.![]()
I'm thinking it may be a bad burn/problem with the compilation (since theres no audio in winDVD for the compilation). I'm going to try changing a few things to see if the audio get fixed and try burning a few more dvds.[/url]
Have you tried any different dvd media? or -R media?
Yea, the media I tried was apparently mid-to-poor range (CMC MAG.M01). I just looked it up using DVD Identifier. Sorta pisses me off because these lightscribes cost quite a bit more than normal dvds.
I'm going to try burning with some Fujifilm DVD+R (YUDEN000T02).
In the meantime, it still won't clear up the problem with the screwy audio though. When I compile the dvd in DVD-Lab and play it in WinDVD theres still no audio for a few of the menus. Not quite sure why this is so
Some MKVs cause MPC HC to flicker but play fine with VLC. Help please?
By elcoyoteloco in forum Software PlayingReplies: 2Last Post: 6th Nov 2011, 23:42 -
SLP has gone bonkers but SP fine on VHS/DVD PLAYER.
By spicy83 in forum Newbie / General discussionsReplies: 6Last Post: 27th Feb 2010, 00:13 -
DVDRW works fine on PC, not on DVD Player
By Koopzer in forum Newbie / General discussionsReplies: 3Last Post: 21st Apr 2008, 03:54 -
x264 audio won't play in GB-PVR or WMP, works fine in MPC
By bigshotceo in forum Software PlayingReplies: 2Last Post: 15th Apr 2008, 10:55 -
DVD Does not Play in Drve, But plays fine in Player
By HellSaber in forum DVD & Blu-ray PlayersReplies: 1Last Post: 28th Feb 2008, 17:13
