  1. Is this possible? I can get the second DVD-r whitout menus. But i cant find out how to do it whit the first one.
  2. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    If the movie is larger than a a DVD5 disc, then you need a program such as DVDShrink or DVD2One.
    Google is your Friend
  3. Member Grain's Avatar
    Oct 2005
    Canada
    DVDFabGold/Platinum won't allow you to remove anything when doing a 2 disc split. If you want to do a 2 disc split for only the movie, you'll have to re-author with another program first, such as Shrink. While your using Shrink, you might as well use it to split the movie, it does that no problem. If you want to keep the menu, but only want the movie, one option is to use CloneDVD first to remove everything but the movie and menu, then use DVDFabGold/Plat to split. Clone will also allow you to split it and keep the menu, but it won't have the "Insert Disc 2" screens that Fab does.
