I am a relative newbie trying to use VCDEasy to burn a simple Video CD. My problem is with burning the CD. VCDEasy has CDRDAO disabled upon startup. I read in the FAQ that came with VCDEasy about the ASPI drivers, so I downloaded and ran aspichk.exe per the instructions, and it appears that no ASPI drivers are loaded (I am running Win XP). I then used aspi32.exe to try to install the drivers, but got an error saying no qualified Adaptec products were found. I then tried ForceASPI 1.7 (I ran the INSTASPI.BAT file per the instructions), but even though a DOS window opens and says the ASPI files are installed, after I reboot, aspichk still says the drivers are not installed and VCDEasy still disables CDRDAO. Am I missing something here? Will the ASPI drivers not install under WinXP?
<font size=-1>[ This Message was edited by: seplant on 2002-01-16 04:27:46 ]</font>
I think i can help you. Email me so i can get your email, and i will email u the needed files..
I also need help with this. I want to make VCDs with VCDEasy and I have WinXP. Thanks.Originally Posted by seplant
Administrator Privilege to Run VCDEasy
By asifmcp in forum VCDEasy GeneralReplies: 2Last Post: 8th Jan 2011, 04:48 -
Burning with VcdEasy
By gkma01 in forum Authoring (VCD/SVCD)Replies: 6Last Post: 19th Sep 2008, 20:00 -
ASPI for XP x64
By HartsVideo in forum Video ConversionReplies: 12Last Post: 6th Jul 2008, 04:20 -
Problem with creaing Menu in VCDEasy
By haris in forum Authoring (VCD/SVCD)Replies: 5Last Post: 16th Mar 2008, 08:17 -
How will I make an AVCD using VCDEasy?
By zeldAIS in forum VCDEasy GeneralReplies: 1Last Post: 4th Aug 2007, 15:13
