    Oct 2006
    Canada
    Hi guys. Normally I use Nero Vision to burn my DVDs and it seems to work great. Is there anything out there better? What I'm hoping to achieve is a better menu system. Would like to be able to create a menu that has say 2 boxing matches as the titles, but also a way to go into a 'Chapter List Menu' and go to say 'Round 5' of a particular fight from the menu.
    thanks!
    Apr 2004
    Miskatonic U
    IMO pretty much everything is better than Nero, except maybe WinAVI. Given you are coming from Nero land and probably want something simple and fast, I would recommend Tmpgenc DVD Author 2. It will do everything you need without a steep learning curve.
    Read my blog here.
  3. Member FulciLives's Avatar
    May 2003
    Pittsburgh, PA in the USA
    TMPGEnc DVD Author 2.0 is a great DVD authoring program.
    - John "FulciLives" Coleman
    Oct 2006
    Canada
    I'll give that a shot thanks guys!
  5. Member MysticE's Avatar
    Nov 2003
    That's easily and quickly done with NeroVision Express and is the Default when creating menus unless you choose 'Title Menus Only".
