Why when I convert avi to vcd it turns it into a Mpeg file instead of a vcd? Errr I am so pissed. I have winavi but everytime I choose to convert an avi file to vcd it turns it into a mpeg FIle! How do I change this.
Results 1 to 10 of 10
MPG 1 is used on VCD. Now you have to use some VCD mastering package to create and burn the VCD.
Set Nero or Roxio up for VCD, and drag the mpeg1 file into the work pane, and burn. If your mpeg1 is not VCD compilance, Nero or .. will tell you.
Can you tell me exactly how to do this? Is ahead nero the same thing as nero? Sorry and thanks for your patience!Originally Posted by Pinstripes23
OK I have a movie I want to play on my cheap APEX dvd player! What format will play. I have watched non dvd movies on this before. MPEG1 doesnt work. Can someone please just tell me a format or program I can use to make a video cd work on this? I dont have a dvd burner either just a cdrw!
See the manual of the cd burning software that came with your burner. If it can burn a video cd, load your mpg into TMPGEnc -File-mpeg tools-multiplex tab-type-select MPEG-1 Video Cd-load your mpg files and remultiplex. Select video cd in burning software and load the remultiplexed mpg files. Burn on a CD-RW and check in your apex.
From Nero Burnging ROM's New Compilation wizard, select CD -> Video CD then press New. Add your MPEG1 file to the complition, burn to CD.
I do this but my dvd player wont play the mpeg formatOriginally Posted by jagabo
I GOT IT I JUST BURNED USED THE CD-ROM[UDF] tab and it worked. For some reason the video cd tab wouldnt work! Thanks to all that helped!
How to convert an .avi or .mkv or .mp4 file to mpgav for burning to a VCD
By jasoothai in forum Authoring (VCD/SVCD)Replies: 8Last Post: 29th Oct 2011, 20:35 -
Trying to convert AVI to MPEG file smaller then 4gig
By Lisn2me in forum Newbie / General discussionsReplies: 7Last Post: 30th Dec 2009, 12:01 -
How to convert an MPEG file to DV-AVI Type 2 using MPEG Streamclip
By MAdNEZ in forum Newbie / General discussionsReplies: 15Last Post: 4th Aug 2009, 08:30 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 13:14 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 02:36
