I look for help because I can't play any DVD disc in a Toshiba Notebook A10 S1001.
I download the soft “DISC Info version 1.6.1” and the results are:
D: TOSHIBA DVD-ROM SD-R2412
Firmware version: 1431
Vendor specific: 08/08/03
Extra info IT
Toshiba SD-R2412
Drive region status: Lock Detected
Region setting status Set
User changes left: 4
Manufactor resets left: 4
Current region set: 1
Read speed: 24x Write speed: 24x
Access Driver: SPTI (WinNT/2k/XP)
I went too to “http://www.toshibaer.com/firmware/SD-R2412 Toshiba Firmware, Use DISCInfo to check the status of your drives”. and found
14 SD-R2412_1431.zip zip 156.1 KB 29-May-06 1431 for the SD-R2412 (FOR DRIVES WITH 14XX FIRMWARE ONLY!)
I download the following firmwares: R2412_1018, R2412-1031, R2412-1615, R2412-X431, made a bootable cd disc with them I try to flash a new firmware. All of them result in HEX FILE ERROR.
Coul'd someone help me with this?
Thank you
Need help with region change for Toshiba Satellite
By Magic Rose in forum DVD & Blu-ray PlayersReplies: 2Last Post: 2nd Apr 2010, 07:49 -
Change region code, how? Toshiba portable DVD player (SD-P1400) 2004 model
By Traxx29 in forum Portable VideoReplies: 0Last Post: 27th Dec 2009, 19:42 -
how to change DVD player region code on Toshiba SDk 730
By sashatheman in forum DVD & Blu-ray PlayersReplies: 1Last Post: 12th Dec 2009, 07:17 -
Need Help: Region Hack for DVD Player Toshiba SD-6100KU Thanks
By Panchogun in forum DVD & Blu-ray PlayersReplies: 0Last Post: 15th Nov 2008, 12:40 -
Change Sony BDP- S350 From Region (1) to Region (4) can it be done?
By MOTHGIRL in forum DVD & Blu-ray RecordersReplies: 1Last Post: 30th Sep 2008, 22:58
