converted from d2v to mpeg and where the file is suposed to be , well it is there but it shows to be nmothing . the file has 0 kb , and does nothing when played??? any help would be much appreciated.
Results 1 to 9 of 9
i have the mpeg nmow , but ive tried burning it wioth nero and adaptec easy cd 5 , no dvd will recognize it.
Look under CONVERT to the left to encode to a compliant Mpeg
~~~Spidey~~~
"Gonna find my time in Heaven, cause I did my time in Hell........I wasn't looking too good, but I was feeling real well......" - The Man - Keef Riffards -
The file must be corrupt, or you encoded it to some variant. If it's a VBR variant stream use an SVCD authroing program, a CBR use VCD
~~~Spidey~~~
i got it to burn and it can play in media player but no dvd see it still . i explored the cd and it burned 5 folders one of them says Mpegav inside that folder there is the file Avseq01.dat , it plays in meadia player . still doesnt recognize in dvds rom or stand alone .
n00b_n33ding_h3lp
since you're using nero and the file name of the .mpg file is Avseq01.dat, i'm assuming u made a VCD and used nero's VCD template to burn the .mpg file?
if you actually made an SVCD, then you should use nero's SVCD template and the .mpg file on the SVCD discs should be Avseq01.mpg -
n00b_n33ding_h3lp,
o i forgot to mention, if you do wanna make SVCDs. make sure your standalone dvd player can play them. check out the dvd compatability guide on VCDhelp.com
MPEG Streamclip / Converted WMV to MPEG-4 but only got the audio? Help me.
By aka_director in forum Video ConversionReplies: 0Last Post: 3rd Oct 2010, 23:24 -
Converted VOB to MPEG-4, Sluggish Playback
By linnium in forum Newbie / General discussionsReplies: 4Last Post: 2nd Jan 2010, 01:04 -
Burn Already converted MPEG Movies To DVD
By killagoob in forum Newbie / General discussionsReplies: 1Last Post: 19th Apr 2008, 21:11 -
Why only one scene visible in a VRO converted to MPEG?
By Stabes in forum Newbie / General discussionsReplies: 3Last Post: 1st Jan 2008, 15:49 -
Already converted to mpeg 2
By nathy85 in forum SubtitleReplies: 7Last Post: 24th Nov 2007, 04:35
