I'm using TMPGEnc Plus to convert my files but I was wondering how do you apply a ssa file to it?
Results 1 to 13 of 13
Right now you are just Converting/Encoding your Video.
if you want to add Subs to the DVD, you must do it in the authoring Stage,
Unless you want Hard Coded Subs. then you cant turn them on and Off they are Encoded into the Video.
Look on the left at what is authoring. -
Which version ? Version 1.x doesn't do subs. Not sure if Version 2 does. If you have an older version then you have a bit of work ahead of you.
Have a read of the links I posted here -> https://forum.videohelp.com/viewtopic.php?t=316686 to find ot how to add subs to an existing DVD structure.Read my blog here.
I use version 1.6 =[. So anyone know if Version 2 can add subtitles?
No, it doesn't support switchable subs. Next version will support subs, see https://forum.videohelp.com/viewtopic.php?t=315025
GUI for dvdauthor (free), DVD-lab Pro, Ulead DVD Workshop...but they are not as easy to use as TDA though.
If you don't need any menus or basic menus you can use dvdauthorgui or muxman. -
I have a few vob files with built-in sub-titles. If I re-author these vob files using TMPGEnc DVD Author (version 1.6) to create menu etc. will I still have the original subtitles in the authored files? There seems to be none when I play them back. Is there any way to restore the subtitles in a TDA authored vob file?
applying different filters to different sections in a clip (via avisynth)
By unclescoob in forum RestorationReplies: 28Last Post: 30th Jan 2012, 14:50 -
Applying multiple filters at once with FFMPEG
By asterixvader in forum Video ConversionReplies: 3Last Post: 1st Jun 2011, 15:53 -
Applying filters to regions of interest (ROIs)
By johnnys5 in forum Newbie / General discussionsReplies: 1Last Post: 6th Dec 2010, 17:29 -
Applying DirectShow to a program?
By terrypin in forum Newbie / General discussionsReplies: 1Last Post: 3rd Sep 2008, 11:08 -
Applying a filter without recompressing in VDub
By chrisr34000 in forum EditingReplies: 5Last Post: 25th Jan 2008, 18:42
