Hi, recently I've been trying to find a way to convert and burn my avi files onto a DVD for better watching experience, but I found it exteremely difficult and timewasting to do it... I tried god knows how many of them programs and couldnt find the one that suits me (i.e. easy enough for a total noob). One time I burned a converted VOB file and the quality was horrible (both video and audio)... The last one i did was actually good enough, but in both cases it took me over 7 hours to burn one dvd from an avi video file...
Then i thought it might be a better idea just to get a xvid/divx compatable dvd player and just burn all my avi onto one dvd and play them from it... From my basic understanding the quality will remain unchanged and you'll be able to store a lot more videos this way on one DVD... Am I understanding it right?
If yes, which DVD players would you recommend in this case...
Any other tips?
Thankx in advance...
P.S. What are the advantages/dissadvantages of doing it either ways (i.e. would I be able to rewind the video in the avi format? etc)
The Philips DVP5960/05 is your best bet. This model is sold in Ireland and the United Kingdom.
Here is a link ---> CLICK HERE
That model is known as DVP5960/37 here in the USA and it is a most excellent MPEG-4 capable DVD player. It should play most downloaded DivX and XviD video files.
This will make your life much easier but if you haven't already tried ConvertXtoDVD then you might want to give it a try. That is a program that converts many different types of files (such as MPEG-4 DivX and XviD files) to standard DVD Video format thus allowing you to create a standard DVD Video disc that will play in any regular DVD player.
Thanx a lot..
btw, that was actually the program (ConvertXtoDVD) I used to create my last DVD... Like I said the quality was great compared to the other.
Follow up question: since I have a lot of 20-30mins files and I want them on one DVD, which program is best to do it with. Have in mind that it would be a great advantage if that program had a Menu (even if its basic) creator... -
Originally Posted by Antibug
If you want to make a standard DVD Video and want to keep it simple then ConvertXtoDVD is really the best tool ... and it does create a menu for you.
Originally Posted by MysticE
My DivX DVD Player can't play my avi DivX/xvid video
By Baldrick in forum DVD & Blu-ray PlayersReplies: 32Last Post: 6th Mar 2015, 09:11 -
Is this DVD Player can play Divx or XviD?
By php111 in forum DVD & Blu-ray PlayersReplies: 19Last Post: 6th Oct 2007, 07:29 -
Best Divx/Xvid DVD Player!!!
By SIRCOOKS in forum ComputerReplies: 10Last Post: 23rd Aug 2007, 10:49 -
Divx/Xvid on dvd player annoyances
By dude112 in forum DVD & Blu-ray PlayersReplies: 11Last Post: 13th Jul 2007, 21:21 -
DivX/XviD file on DVD player
By Bizouman in forum Video ConversionReplies: 4Last Post: 4th Jul 2007, 02:36
