I have a sattelite card in the pc and am capturing some HD content, was wondering how I could remove the commercials and convert to AVI the easiest.
the format its saving it in is MPG (mpeg 2 I believe for dvd).
Software in use is mytheatre.
Thanks!
Results 1 to 11 of 11
You can use VirtualDubMod - it accepts MPG files, you can select bits to be removed, and can use any installed codec to output to AVI.
It's free, and there's plenty of guides explaining how to do what you need to do.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
I can't see how you can set multiple ranges, so it looks like - unless anyone knows how to do it differently - you'll have to set your start frame, end frame and Del (delete) to remove the unwanted frames - and repeat...
Carpe diem.
Pretty much. One at a time is how virtualdub does it. For commercials it isn't that bad. For real editing it's horrible.
Read my blog here.
ok ive figured it out, but virtual dub mod doesnt allow any sort of compression of the audio. I'm getting AC3, must I use dgindex and then throw it into vfapi and then into regular virtual dub and do all the work on that?
OR is there a way to compress the audio in virtualdubmod ? -
Originally Posted by kamaleon"Art is making something out of nothing and selling it." - Frank Zappa
Yes, that's right. But i suppose he could remove the commercials then convert to avi using another tool
I use Pinncale Studio 8.... Works perfect, you wanna see? I put it on Google Video, its Pinks! All Out - http://video.google.com/videoplay?docid=6065538802002442278&q=Pinks%21+All+Out
Project Digital: Eliminate All Physical Media is finally underway!
connecting sattelite reciever box, tv, and dvd recorder.
By steve6 in forum MediaReplies: 4Last Post: 19th Feb 2011, 13:56 -
FFmpeg - Removing commercial breaks from mpeg TV recording
By Chris_Smith in forum Video ConversionReplies: 0Last Post: 19th May 2009, 03:43 -
Connecting a Sattelite receiver to a DVD recorder
By nicewithice in forum DVD & Blu-ray RecordersReplies: 4Last Post: 30th Jul 2008, 12:59 -
going from wmv/mpg to flash video on a commercial site
By Fking in forum Newbie / General discussionsReplies: 3Last Post: 18th May 2008, 08:14 -
TV Sattelite on PC?
By kopenhagen in forum DVB / IPTVReplies: 0Last Post: 25th Nov 2007, 20:19
