    Jul 2006
    Hi,
    I need to know how to easily overlap video frames in to 1 frame for a movie! I'm a making a movie with my friend
    Joe
    Apr 2004
    Miskatonic U
    Your question doesn't make sense. You need to elaborate.
    Do you want to overlap each clip by one frame, or compress all the frames into a single frame ?
    Read my blog here.
    Jul 2006
    I want to overlap each clip by one frame
  4. I'm not sure I understand either. You want to take a video clip, and overlay it on the same video clip, but just shifted over by one frame, so the result looks kind of blended/blurry? Something like this, where the letters stand for frames laid on top of each other:
    ABCDEFG
    BCDEFGH
    Anyway, if you want something similar, then I think that AviSynth's Overlay command can help. One script will do what I just described:
    A=MPEG2Source("C:\Path\To\Video.d2v")
    B=MPEG2Source("C:\Path\To\Video.d2v").Trim(1,0)
    Overlay(A,B,Opacity=0.5)
    I was just testing with a DVD source. You can also use an AVI source:
    http://www.avisynth.org.ru/docs/english/corefilters/overlay.htm
