My dvd writer is TDK-DVDRW880N, and although I've installed the latest firmware, it still keeps giving me this error.
"failed to start disc-at-once". I've attached the log for more info.
The disc type is DVD -R. I've always used this type of disc in the past, but for some reason now it's not working. I tried burning CDs and it works.. only DVDs they are giving me this error message.
Help is very appreciated!
burner.txt
Dosent look right ...
The drive is reported as "usb" ... is it in an external case ?
Make sure the correct bios is used for the unit ... be very specific .
The media may just be a bad batch .
Determine maximum speed : FALSE = fine
Simulate : FALSE = fine
Write : TRUE = fine
Why ?
Finalize CD : FALSE
Multisession : TRUE
Multisession type: : Start multisession
When
Book Type: DVD-R
Last possible write address on media: 2298495 (510:46.45, 4489MB)
Dvd should be closed ... not done in multisetion mode ?
Prior to bailout :
End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB) <<< not right .
(suggests you jammed 892+ dvd-r's into drive at the same time)
The media / batch is dud .
Before getting another batch or brand ... run imgburn as a test run ... it's even possible nero stuffed up or needs to be totally uninstalled using nero's clean out tools , reboot , and reinstall to fix .
Blu Ray and burning a Data Disc...not a Video Disc
By Moontrash in forum DVD & Blu-ray WritersReplies: 16Last Post: 16th Dec 2019, 22:18 -
Where to start? I'm a amateur photographer and I want to start out in video
By James Wright in forum Newbie / General discussionsReplies: 14Last Post: 3rd Jul 2015, 14:12 -
Matshita BD UJ240AS doesn't work (not perform start of Disc-at-once)
By whenloverageswild in forum Authoring (Blu-ray)Replies: 5Last Post: 11th Nov 2011, 02:08 -
Copping Disc - Disc Data Recovery Software.
By Teac23 in forum DVD RippingReplies: 5Last Post: 1st Oct 2010, 20:06 -
Titlewriter 4.65 disc compliance failed ....... Fallen Angle please see me
By Devoir in forum Authoring (DVD)Replies: 22Last Post: 15th Mar 2010, 09:49
