Can someone tell me what I am doing wrong.
I am working on adobe premiere pro 2.0 and wanted to install the shine plug-in.
I installed the file chose the plug-in directory and verified that the folder trapcode containing the file Shine.aex was present in the plug-ins directory. I have restarted premiere and rebooted the computer but when I go to the effects area I cannot find the trapcode folder nor the shine plug-in. I really need this file for an effect and can't wait for their customer support. Thanks for your help as always.
I have the Trapcode Shine plug-in installed here:
C:\Program Files\Adobe\Premiere Pro 1.5\Plug-ins\Common\Trapcode
...and I can see it in Premiere Pro 1.5There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
that was it.
Rather than installing the file in the Common folder it was just placint it in the plug in directory and adobe wasn't recognizing it there.
Again thanks
What is this plug??
By trunksu in forum Newbie / General discussionsReplies: 3Last Post: 1st Feb 2011, 05:09 -
Ripping "Shine A Light" problems
By robertazimmerman in forum DVD RippingReplies: 7Last Post: 11th Aug 2008, 18:50 -
MS Media Player plug-in
By AndreL in forum Software PlayingReplies: 1Last Post: 7th Jun 2008, 16:01 -
LG KE970 Shine video
By ruud_vx in forum Portable VideoReplies: 2Last Post: 22nd Mar 2008, 10:42 -
Problem with NeatVideo plug-in...
By beckmen in forum RestorationReplies: 0Last Post: 10th Mar 2008, 18:50
