Well look i have a bunch of vcds taking so much space how can i convert them to avi with a lower storage size and still keep the quality if that is even possible please help me out. thanks in advance
You can extract the MPEG files from your VCD's and compress them with DivX using VirtualDub. You'll be compressing a "lossy" file though, so there will be a quality loss to a degree. Setting a bitrate between 600 and 910 will usually give you a good quality DivX and still result in a smaller file.
Extract the MPEG files using VCDGEAR. Read the help here:
http://www.vcdhelp.com/convertdat.htm
http://www.vcdhelp.com/avi2divx.htm
Download Virtualdub: http://www186.pair.com/vdub/
Download and install DivX: http://www.divx.com
AVI to VCD
By Slip Kid in forum Newbie / General discussionsReplies: 4Last Post: 24th May 2009, 00:40 -
avi to vcd
By cornick in forum Video ConversionReplies: 4Last Post: 11th Aug 2008, 20:12 -
AVI to VCD
By northy44 in forum Authoring (VCD/SVCD)Replies: 4Last Post: 6th Dec 2007, 06:27 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 12:14 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 01:36
