I'm try capture my old VHS's tru hauppage 150. That is optimal settings for WinTV? Capture in NTSC. Thank you for advice![]()
I have the PVR-350, so I'm not sure how different the 150 is from that, but I have a few suggestions. If you are allowed to capture at a resolution of 352x480 then do that instead of 720x480. The lower resolution is closer the VHS's natural resolution (which is something like 240x480) and will allow the bit rate to be used over a smaller area, which should improve quality. You'll get more bits per pixel and the quality should be better. Use a bit rate calculator and set the bit rate accordingly. VBR might be a better choice than CBR for VHS tapes and my advice would be to set the average bit rate to a little lower than the bit rate calculator says to use (maybe 100-200 Kbps lower) and set a maximum bit rate of 2000 Kbps above the average and a minimum of 2000 Kbps below the average. Set the audio bit rate to 224 or 256 as you won't gain very much space from a lower bit rate but you might get worse audio quality.
Optimal for what? Best possible picture quality period? 1 hour on a DVD? 2 hours on a DVD? 8 hours on a DVD?
vbr would probably not gain any space on such a poor compressing source (vhs is very noisy)
Optimal settings for conversion
By airwolfUK in forum Video ConversionReplies: 1Last Post: 17th Feb 2011, 15:08 -
Optimal Settings for WMP Streaming Video
By john_doe1 in forum Video Streaming DownloadingReplies: 9Last Post: 24th Sep 2009, 19:12 -
Blue screen when installing Hauppage WinTV 150 drivers from website
By ponyboy in forum Capturing and VCRReplies: 1Last Post: 5th Mar 2008, 23:55 -
Color Bleed on Hauppage WinTV-PVR 150
By TheBladeRoden in forum Capturing and VCRReplies: 3Last Post: 14th Jun 2007, 10:05 -
Optimal xvid settings
By Ygramul in forum Newbie / General discussionsReplies: 1Last Post: 13th Jun 2007, 16:10
