    Dec 2006
    i have 8 cartoon episodes would like to put in dvd. using dvdlab pro how would i create an regular menu nothing fancy with episode selection? thanks
  2. Member steveryan's Avatar
    Jan 2003
    Manchester
    Go to the menu
    select the text icon
    type "episode 1"
    right click the text you have just done
    link to first episode
    type "episode 2"
    link to second episode etc...etc....
    He's a liar and a murderer, and I say that with all due respect.
    Dec 2006
    i read somewhere that if you have like 5 episodes you need 5 vts menu? im just trying to make a simple menu with 7 episodes selection, dont i just need 1 vts menu for that? how do you put music in the menu also? where these draw link pose to be linked to menu to episode so it plays right is kinda confusing. ive been playing with this program for over an hour trying to make this menu with 7 episodes but cant seem to get it right can someone help me with this.
    Apr 2004
    Miskatonic U
    If the video has the same aspect ratio (e.g. all 4:3 or all 16:9), the same resolution, and the same audio format, then they can all be in the one VTS.
    Start a new project. Pick Normal (VTS Menu + Movie). Import your audio and video assets. Create the extra movie objects (you get one by default - you need to add the other 6). Put your movie assets into the movie objects (double-click on the movie object in the tree, then drag the assets up to the movie object screen).
    Once you have all your movies populated, double-click on the Menu object in the tree, and add your text and images to the menu. Right-click on each menu choice and follow the menu to your movie object (be default these are called movie 1, movie 2 etc, although you can rename them if you want).
    Once you have them all linked, go to the Connections window and make sure your First Play itme links to your menu. Compile and test.
    Read my blog here.
