I have some AVI files I'm trying to encode with Nero Vision so try to encode wait for it to finish but about two minutes into it Nero will crash forcing me to do a hard reset. I had read that my Nero version was unstable so I downgraded to 6.6.0.18 did that and the same problem I've upgraded my dvd burners firmware to the latest out defraged hd , tried uninstalling other programs and still Nero will crash forching a hard reset. I have tried to encode the files with other programs and still I have to hard reset. Someone must know whats going on here right? Thanks in advance.
Results 1 to 11 of 11
NeroVision is rubbish. There, I've said it.
If you must use a one-click program, try ConvertxtoDVD. It is stable, much more reliable than NeroVision, WinAVI etc., and is much less likely to have audio sync problems.
If you must use NeroVision (and for some reason, some people insist on using it), replace the audio in your avi with uncompressed PCM audio before processing.Read my blog here.
didn't play at first so I got Codec Pack 2.0.6 and dl from ive installed a codec pack i got there
Start by uninstalling it, if it has an uninstaller. Then use something like CodecSniper to try to find bad codecs and remove them.
Use programs like g-spot or avicodec to determine what codec you need, and install just that codec.
It is not unheard of for codec packs to leave a system in such a state that only a reformat and reinstall of Windows will fix it.Read my blog here.
meGUI Nero AAC encoding error
By ArtOfLosingMFZB in forum DVD RippingReplies: 4Last Post: 16th Aug 2010, 13:46 -
Nero Recode encoding problem
By goodmedo2003 in forum Video ConversionReplies: 4Last Post: 30th Apr 2009, 11:35 -
nero smart encoding
By m baqar in forum Authoring (DVD)Replies: 4Last Post: 27th Mar 2008, 06:13 -
nero 7 out of sync encoding
By sharky007 in forum Authoring (DVD)Replies: 1Last Post: 25th Jul 2007, 05:28 -
Question for Those Who are Familiar with Nero 6 or 7 on Encoding to MPEG-2
By wayney in forum Newbie / General discussionsReplies: 11Last Post: 13th Jun 2007, 20:35
