Results 1 to 9 of 9
  1. I have dvd I durned from a stand alone player. I want to take and put it on youtube. Whats the method with the least amount of steps. I used rejig to take the the video from the dvd but I cant seem to get the audio to work once I convert it with riva flv.
    USA
    You could use the freeware VOB2MPEG to get the whole DVD to a large MPEG-2 file. From there, it depends on your software to convert to FLV with audio.
  3. I tried it but when I transfer it with flv encoder, the file wont convert with sound. flv wont recognize the codec.
    Apr 2004
    Miskatonic U
    I haven't used Riva, so I don't know what it is looking for. Try installing AC3 Filter or AC3 ACM Decoder in case Riva simply can't open the AC3 file. If this doesn't work you may have to manually convert the audio to something else like PCM or CBR MP3 before converting the whole lot to flv.
    Read my blog here.
  5. I cant get riva to work. I downloaded virtual dub and I get a message"invalid pack, marker bit not set, mpeg2 stream". which I have no idea what it means. maybe its the file. I copied the file from dvd with vob2mpg2. Can rejig resize it? I just want it 100mb for utube.
  6. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Only Virtualdubmod or virtualdubmpeg2 can open mpegs. That said, they can also open vobs.
    I thought YouTube preferred to get Xvid files and do their own conversion.
    Read my blog here.
  7. Is there something out there thats free. I want to download a dvd file and convert it to 100 mb avi or mpeg, whatever is fastest. only thing I can get virtualdubmpeg2 to do is make huge avi files.
  8. Member rhegedus's Avatar
    on the jazz
    ...then use a decent codec. You're probably saving uncompressed avi.
    Install DivX 6 and you'll see it available in VirtualDub under the Video > Compression tabs. There's plenty of output options available.
    Like wise, you'll need an audio codec too Audio > Full Processing Mode > Compression.
    Regards,
    Rob
    Feb 2004
    Australia
    Super will convert to swf / flv without problems .
    Mpeg info :
    Virtualdub , handles avi / mpeg1 .
    Virtualmod , handles avi / mpeg1 / mpeg2 / vob .
