Hi, I was wonderinf there was a way to remove commercials from a movie on a mac. I found Cbreak it seems like a good idea but it is only for windows. I don't know enough to port it to mac. So if anyone knows a quick and dirty way to remove commercials that would be great else I can edit them out manually in Finul Cut Pro HD.
thanks, elictricocean
Results 1 to 10 of 10
You would likely get more answers asking Mac specific questions in our Mac Forum. Moving You.
And welcome to our forums.
What format is the movie in? MPEG Streamclip can cut and trim several different formats.
they were in .TiVo file but I converted them to .mpg ithink MPEG-2, then I converted it to iPod fomat
"Converting to converting to converting, but oops
I forgot to take out the commericals..."
If you have the original files, then you should go back
and open them in MpegStreamclip ( if it will handle
.tivo), trim cut, etc, THEN save to Mpeg-2 or
whatever final format.
but at this stage ( of ipod format) anything we point out will
just degrade the quality further when you save it.
a little fore thought goes a LONG way....
"Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User -
the .tivo is an mpeg2 with a wrapper. I removed the wrapper and got a a plain mpeg2 file.
Darwine doesn't groke it, I don't have an intel to try parallels, and I hate every other emulator for the ppc becuase they are too slow like Q, QEMU, VPC and so on
How we can remove commercials from a video cd without loosing quality.
By nusratjaveid in forum EditingReplies: 1Last Post: 4th Dec 2010, 10:17 -
How to edit/Remove Commercials from .ts files captured by ProgDVB?
By MounaLafi in forum DVB / IPTVReplies: 4Last Post: 2nd Oct 2009, 06:41 -
Mini How-To: Edit Transport Streams to Remove Commercials
By Soopafresh in forum DVB / IPTVReplies: 4Last Post: 6th Aug 2009, 07:15 -
how to remove commercials from wmv files?
By sumeshkri in forum EditingReplies: 1Last Post: 22nd Nov 2008, 18:32 -
Remove commercials from a radio recording mp3
By jmiller29 in forum AudioReplies: 10Last Post: 27th Jun 2007, 12:49
