I have bought a IEEE1394 Laptop CardBus that goes into PCMCIA Slot and am trying to connect it with my desktop computer. I have cable with 6 pins on each side and I plugged in into the card and into my desktop. At this moment I am not sure what to do. I see that device is working fine, but how do I send the signal from it to my desktop?
moved to another forum, nobody likes me here...
Have you tried the XP Networking Wizard? You can find it in 'Control Panel>Network Connections', same place as your LAN connection, then just click on 'Create a new connection'. You set it up the same way as a LAN connection.
I did connected a different laptop to my desktop which has build in IEEE1394 and had no problems setting up network. I m a little bit confused here since the signal comes from PCMCIA, but that should be the same thing right?
moved to another forum, nobody likes me here... -
What operating systems do you have on each?
When you say "how do I send the signal from it to my desktop", you're not trying to send a video stream to it are you? i.e., treat the laptop as a DV device? (Sorry if that's a dumb question!) That isn't possible without additional drivers (i.e., it is technically possible to make the computer appear to be a real AV/C device, but that's another story!)
IEEE-1394 networking using TCP/IP is only supported on certain versions of Windows.John Miller -
Originally Posted by JohnnyMalariamoved to another forum, nobody likes me here...
No matter what 1394 device is installed it's designed to work. PCMCIA is just fine. I was using it for a long time without a single hiccup.
[quote="fLYtRap"]
Have you looked in Network Connections to see what's there?John Miller
My IEEE 1394 cable can't be detected
By edhani in forum Capturing and VCRReplies: 1Last Post: 14th Jul 2011, 07:19 -
IEEE 1394 card
By beavereater in forum ComputerReplies: 1Last Post: 21st Jun 2011, 04:28 -
IEEE 1394/MS DV ERROR
By sampatman in forum Capturing and VCRReplies: 1Last Post: 12th Feb 2010, 10:54 -
Laptop IEEE 1394 doesn't recognize camcorder
By NautTboy in forum Capturing and VCRReplies: 4Last Post: 21st Jan 2010, 20:15 -
is the IEEE 1394 Adapter port necessary...
By roochie in forum MediaReplies: 15Last Post: 15th May 2007, 19:03
