    Dec 2006
    Brazil
    I've heard that if you buy a DVD Writer in a diferent region than where your computer was bought, you will have conflicting hardware... and you must use cracks or similars to overcome this problem....
    For example if you buy a DVD Writer in Germany and use it in a brazillian Computer, will there be any hardware problems/conflicts ?
    I know only of recording problems that are affected by DVD Regions...
    Anyone know anything ?
    Insight apreciated !
    USA
    You can change the region setting 5 times, then you are stuck with the last one. But there are programs that get around that issue. There are several avialabe in our 'Tools' under 'DVD Rip Tools': https://www.videohelp.com/tools?s=7#7
    The region setting is in Control Panel>System>Hardware>Device Manager' then look in the 'Properties' for your DVD drive.
    And welcome to our forums.
    Dec 2006
    Brazil
    Uhm...yes ...I know that, I've read it in the guides and How-Tos ...
    but i want to know about HARDWARE PROBLEMS IN ONE COMPUTER,
    INVOLVING:
    DVD Writer FROM A DIFERENT LOCATION/REGION THAN THE REST OF THE MACHINE !!!
    If I bought a DVD Writer diferent from where my machine is from, would there be any problems with the HARDWARE ?!
    Dec 2006
    Brazil
    and thank you for welcoming me ^^, Ive been visiting this site for quite a while now, but only know I found sth taht wasnt already available here
