I've just bought some expensive 2nd hand orignial audio commentary CD's but they have some bad scratches
can anyone suggest a good CD ripper that will get as much of the original audio as possible without hanging for ages due to read errors? I don't mind the clicks you sometimes get due to scratches as I can remove those afterwards
Results 1 to 9 of 9
Maybe they can be cleaned up before you rip them.Originally Posted by MackemX
I read once about a trick with toothpaste that helps eliminate
some scratches.
Also a cd rejouvenator (sp?) might clean them up if used lightly.A man walked into his son's room and said..."Son, that will cause blindness."
The boy said, "Dad, I'm over here." -
some of the scratches are right through the layer as you can see through if you hold them up to a light
If they're valuable to you maybe it wouldn't cost too much to have
them professionally transferred to files that you can work with.A man walked into his son's room and said..."Son, that will cause blindness."
nah I wouldn't go that far although these CD's (20 CD's in total) are close to $500 to buy new but I got them for a lot less
I'm sure I can salvage most of them as not all are scratched badly. Once I find a good ripping tool I should be able to get a decent backup copy I can use without my CD player struggling to read the bad CD's or risk damaging them any more
I'd like something like ISOBuster that I've used in the past for damaged DVD's or will that also do CD's? (I best fire it up and check then
Here's some posts.
I didn't read all of it...
http://www.hydrogenaudio.org/forums/lofiversion/index.php/t49780.htmlA man walked into his son's room and said..."Son, that will cause blindness."
Isobuster is ripping it now
but it's come to a bad sector and giving me 4 options
#1 Omit sector
#2 Replace with all Zeroes
#3 Replace with User Data All Zeroes
#4 Replace with Erroneous Sector
can anyone suggestion which option is best to use for an audio speech CD? -
looks like I should be trying Exact Audio Copy after reading that thread but I'll let Isobuster finish this CD anyway
scratched discs
By avextraxjp in forum Newbie / General discussionsReplies: 2Last Post: 13th Feb 2009, 17:42 -
what's a good scratched/faulty media ripper?
By MackemX in forum ComputerReplies: 11Last Post: 7th Jun 2008, 09:58 -
How can I recover a scratched dvd/
By wan2no in forum Newbie / General discussionsReplies: 2Last Post: 17th May 2008, 02:48 -
Recovering scratched audio CD
By Des in forum AudioReplies: 11Last Post: 31st Mar 2008, 07:54 -
What player for scratched DVD's?
By mad_max911 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 21st Sep 2007, 09:43
