    Dec 2006
    Canada
    I am having a problem that I hope someone can help me with.
    I am using Nero Vision from Nero Burning Rom version 7.
    Computer is P4 2.4 GHz 1.0 gb ram Windows XP SP2 with an
    LG DVD super multi writer, using DVD+R discs.
    The problem is the file size for avi's. Sometimes I can burn a
    700 mb file to a 4.7 gb disc and sometimes Nero vision tells me
    that the file is too big for the disc. This doesn't make sense to me.
    I know Nero Vision has to change the avi [transcode] it to a
    proper format.
    I try to keep my avi's [downloaded] to 700 mb and under, this seemed
    to work for a while but, increasingly I am get the "TOO BIG" msg
    more and more.
    Can anyone explain to me why its OK sometimes and not others?
    Is there any workaround for this ?
    [better burning software?]
    [different settings in Nero Burning Rom?]
    [another piece of software that would tell me file is too big
    after transcoding]
    It is immensley annoying to wait for 4 - 12 hours for a
    downloading of an avi file, only to find I have to try to find another
    download that may or may not be the right size.
    Read https://forum.videohelp.com/viewtopic.php?p=1595171&highlight=#1595171 , for an explanation of the video file sizes.
    And try convert with another all-in-one tool like ConvertXtoDVD, fast, good quality and supports most video formats.
    Dec 2006
    Canada
    Thank you for reply
    I am now using ConvertXtoDVD instead of nero for transcoding, altho I still use nero to burn.
    ConvertX is slower but that may be my machine.
    Anyway output is much better.
    dabud
  4. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    You could save a lot of time, hassle, and dvd's by purchasing a dvix certified dvd player. Then just burn the files to dvd as data and play...no conversion necessary.
    Google is your Friend
