I just completed construction of a 50 unit apartment building and wired it with RG-6 homeruns to basement. CATV brought cable to basement. Now they are saying that our wiring is inadequate and that we should have used RG-11 and that it is going to cost a lot of $ for them to re-wire, boost, etc. 4-stories, longest run 350 feet. Then the Dish guy says it's just fine! Any leads, adivice, links welcomed! Has protocol changed or am I just getting CATV run around?[/list]
350' thru RG-6 is quite a long run. At 750 Mhz you can expect to lose about 6 db per 100'. With a typical tap output of 20 db you'll be hitting the apt right around 0 db. This is fine, if you don't split it at the apt. A 4 way split will drop each leg 7 db, and you start getting 'out of spec' on your levels. Most modern equipment will operate down to -15 to -20 in analog before snow is objectionable, but due to QAM and other modulation techniques digital may need higher levels. Especially because cable companies usually put digital on the higher frequencies. CATV is usually designed for 0 db at the receiver.
Nobody welcomed you ... so I will ...
Welcome RAD to www.videohelp.com .... and we hope you will have a Merry Christmas and a Happy New Year.
over the air antenna w/ pre installed wiring from cable
By carlos28355 in forum DVB / IPTVReplies: 4Last Post: 26th Sep 2011, 00:10 -
Wiring configuration for HTPC
By Haopengyou in forum Media Center PC / MediaCentersReplies: 1Last Post: 19th Apr 2011, 21:03 -
Legal - Apartment Complex Wants to Wire Own OTA Network
By Frank-0-Video in forum Off topicReplies: 9Last Post: 16th Feb 2009, 09:42 -
Tapping phone of apartment next door
By DeadLily in forum Off topicReplies: 5Last Post: 17th May 2008, 17:31 -
Reliable Company to provide cables for a Long Cable Run
By xixzer0xix in forum DVB / IPTVReplies: 6Last Post: 16th Nov 2007, 18:45
