    Dec 2005
    Canada
    Can someone give me a recommendation on a CD ripper program that rips to mp3's etc?
    I used Window Media player but it only rips to .Wav.
    I need a good program to maintain a library, rip to mp3 or WMA and also normalize the music.
    This is for backup purposes only.
    Oct 2003
    Scotland
    Version 10 of Windows media player rips to mp3.
    You have to set it in the options to use mp3 or wma.
    What version are you using ?
  3. I believe Goldwave will do what you want.
    It is a very flexible program with a solid reputation and I believe they still offer a trial period so you can experiment and try it before buying.
    http://www.goldwave.com/
  4. Member steveryan's Avatar
    Jan 2003
    Manchester
    Cdex or EAC, both free.
    He's a liar and a murderer, and I say that with all due respect.
  5. Member dwill123's Avatar
    Aug 2003
    1 more for CDex. Unbelievably simple to use and very effective.
  6. Member Cornucopia's Avatar
    EAC.
    Best Quality
    Most Thorough/Tweakable
    Many 3rd party encoding output options
