Hi!
I need some help i'm a newbie at "copying" dvds and need some help.
I have friend in the states that sent me a region 1 dvd that i cant play on my dvdplayer cause it only plays region2 dvds.![]()
But how do i make a copy that works in my region 2 dvdplayer??.
I have tried dvdshrink but i dosent work ??!.
How should i do this cause i really wanna watch this movie on my dvdplayer/tv and not on my computer.. how do i make a copy that i can watch in my dvdplayer??.
Thanful for any help i can get![]()
IIRC, DVDShrink removes the region protection code if you don't tell it to do otherwise. If not, tell it to remove the region protection code.
Chances are that you're dealing with a TV system problem tho... - RPC should affect computer playback as well, if you haven't made your computer DVD reader region free.
/Mats -
Well i dont know cause i can watch the movie on my computer with out
a problem.
I used dvdshrink but the dvdplayer shows a screen with an "error" message and it says: the disc is not formatted to play this region.
but my tv can play ntsc format cause i have another movie that is ntsc format but i dont think its region protected
and that one works??.
Try ripping it again, and set DVDShrink to set RPC to 2. OTOH, I think some players use that as a generic error message for DVDs it can't play - could also mean wrong TV system, but you say it plays NTSC (as most PAL players)...
If you rip with DVDDecrypter?
/Mats
Euroline DVD100 DVD Player Region all region code/hack?
By mjgjhb in forum Newbie / General discussionsReplies: 0Last Post: 21st Jul 2011, 09:26 -
Making a Region 1 Player Region Free. Can't find code.
By KitanaAsh in forum DVD & Blu-ray PlayersReplies: 3Last Post: 9th Feb 2010, 08:28 -
Region Code Samsung ht-bd1220 - Code does not work
By mhschenk in forum DVD & Blu-ray PlayersReplies: 1Last Post: 11th Oct 2009, 14:44 -
Need code for pioneeer bdp lx70 code for multi region ...
By SHERWOODSelectrical in forum DVD & Blu-ray PlayersReplies: 2Last Post: 21st Nov 2008, 12:42 -
Sony DVP-FX720 region restriction - using DivX waiting for region free code
By wig in forum DVD & Blu-ray PlayersReplies: 1Last Post: 27th Aug 2008, 04:34
