  1. Member sjmaye's Avatar
    Aug 2003
    Hendersonville, TN USA
    I am new to ripping. I want to use some video from a DVD in a home DVD project I am working on.
    I used Rip4me and it worked great. I got the vob I needed, then used VOB2MPG to get an mpg to use.
    Playback is at time choppy. Am I doing something wrong?
  2. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    Playback on what? Did you verify playback before converting to mpg?
    If all else fails, try again.
    You could also try this guide here: https://www.videohelp.com/guides.php?searchtext=&tools=&madeby=&formatconversionselect=...or+List+Guides
    Google is your Friend
  3. Member sjmaye's Avatar
    Aug 2003
    Playback on my PC. The picture stutters periodically. I first saw it when I placed the mpg file in my video editor and was previewing. I thought it might be just a glitch with the preview mode in the ditor, so I went ahead and created a mpg file with the editor. Go the same thing.
    I feel certain if I re-encoded it would straighten up whatever is causing the stutters, but I don't want the loss in PQ. I just wondered if there was some program or something out there that would take care of the stutters without affecting PQ.
  4. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    Possibly low system resources, high cpu usage, heavily fragmented HD, corrupt file, or some other error in the file caused during the vob to mpg conversion.
    You can check your resources and cpu using task manager.
    I'm sure you already know how to defrag your HD.
    To rule out file corruption, you could perform the RIP and conversion a second time.
    Dec 2006
    So in a nutshell, the most likely reason a dvd that plays well in Total Video Player but clips audio and skips video on any attempt at conversion with Total Video Converter, is due to my computer shortcomings? Or any other suggestions before giving up. Thanks
  6. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    Are you sure you are responding to the correct thread?
    If you are the same person, you didn't mention Total Video Player before now. You just stated that it didn't play correctly after conversion.
    Try a different player. PowerDVD is a quality player if you have it. If not try MPC or VLC.
    If it still skips with a different player, then I suggest checking everything listed above and performing the conversion again.
  7. Member sjmaye's Avatar
    Aug 2003
    No, I am afraid I was the original poster. I am still working through my probs. Thanks for all your tips!
  8. Member sjmaye's Avatar
    Aug 2003
    REMOVED
