I want to capture tape from digital camera to computer in yv12 colorspace. I am in pal country, file is DV avi interlaced, 25 fps.
I know that Pal using yv12 colorspace. And when capture to dv is better to decode to yv12. So i am using cedocida dv codec with yv12 option. So when transfer to computer, if i that file load in CCE does my encoded file be yv12 ?(becasue i know that cce work with yuy2).
Or what happened if i that dv file load in Pinnacle studio or Sony vegas, does colorspace still be the same yv12 ?
Results 1 to 9 of 9
Hi-
This isn't really my speciality, so don't ask anything any harder than this. If at all possible, you want to cap in YUY2, if it's going to CCE for encoding. If you don't, and don't convert it to YUY2 in your script, CCE is going to convert it to YUY2 anyway. CCE will output YV12. You can check the video (colorspace and many other things) at any stage by creating a script for the video, adding Info() at the bottom, and then opening it in VDubMod. -
Originally Posted by SerbianBoss
With the option enabled it compresses the video without any problems but opening the Picture Quality dialog gives the same error (the dialog continues to run). Everyone says CCE works in YUY2 internally so maybe that's why. If that's the case, CCE converts to YUY2 for its filtering, then back to YV12 for MPEG compression. You might see some differences between having Cedocida do the YV12-to-YUY2 conversion vs having CCE do it (are the U and V samples duplicated or interpolated?). Try both options and see if there's any difference in the final output.
four YV12 pixels:
Code:Y1 Y2 Y3 Y4 U1 V1
Code:Y1 U1 Y2 V1 Y3 U1 Y4 V1
@jagabo
thanks for info.
Questions about HC
1. IF we have interlaced material does we need to select "interlaced" in miscellaneous
2. Scan method- need to be alternate for interlaced material
3. CPU-is better to select auto or SSE3(because my cpu support sse3)
4. In matrix option is better to select built in matrix or custom matrix
thanks -
1. Yes
2. Yes
3. I don't know. I kept mine at auto. It should be able to detect it, I think.
4. I usually use a custom matrix. It kind of depends on how much space you're allowing and how well the material compresses. Check the average quant when done. That's a good indication of quality, and whether or not you allowed enough space, or chose the proper matrix for the file size.
unsupported colorspace - x264 requires yv12
By codemaster in forum Video ConversionReplies: 17Last Post: 3rd Jan 2012, 10:30 -
Confused over colorspace (YV12) and DV AVI
By sasuweh in forum Video ConversionReplies: 4Last Post: 30th Sep 2010, 05:34 -
What is Native DV(PAL) colorspace? YV12 or YUY2
By Josip in forum Newbie / General discussionsReplies: 7Last Post: 13th Nov 2008, 23:25 -
DVD to DVD: YV12 to RGB to YV12, color problem ???
By cd090580 in forum RestorationReplies: 9Last Post: 24th Oct 2008, 10:16 -
Sony Vegas YV12 colorspace
By MagicSparky in forum EditingReplies: 4Last Post: 8th Mar 2008, 12:40
