help please its getting on my nerves now
i got this program about 10 months ago downloaded it payed for it and averthing was great i use it for putting 2 vcds on to 1 dvd dead easy for me (with being a thicky) it would run through and then burn to a disc using dvd decrypter great
last week i had to flatten my computer and start again downloaded it again put my reg number in now it runs right to the end but does not burn
can any 1 please help
i tried the burners on there own and there r ok please help and stop me going mad please
It seems that SVCD2DVD can not find your burning program. Are you using IMGburn? Have you made sure that SVCD2DVD knows where your burning application is? I had a problem where I saved a bunch of projects while I was using DVDDecryptor to burn. When I switched to imgburn, SVCD2DVD no longer burned for me. It seems that even though I selected to use imgburn after loading a project, SVCD2DVD tried to use DVDDecrytpor because that was what the project file told it to use. Hope this is of some value to you.
Mark -
mwkurt is correct. redo your settings and use ImgBurn in the burning settings... If you haven't got ImgBurn installed then you should download that first.
all the setting are diffrent than the last version
in the settings boxes are all empty what sould i put in them
sorry for being thick but dont no thanks for your help
i downloaded the dvd burner you told me two but dont no about the setting sorry
I need a DVD movie supplier, PLZ!
By caesarhawy in forum Off topicReplies: 0Last Post: 17th Mar 2009, 02:54 -
Dual Layer DVD successfully burned, but won't play on a DVD player Help Plz
By Ruudboy in forum Newbie / General discussionsReplies: 9Last Post: 13th Dec 2008, 03:09 -
encoding and dvd authering help plz
By lucid_dreams in forum Newbie / General discussionsReplies: 3Last Post: 6th Mar 2008, 17:05 -
DVD Lab Pro 2.5 help plz
By lucid_dreams in forum Authoring (DVD)Replies: 15Last Post: 3rd Mar 2008, 16:13 -
tmpg dvd author 1.6 help plz
By nwa in forum Authoring (DVD)Replies: 8Last Post: 6th Jul 2007, 19:59
