In dvd lab when I go to compile my dvd it completes the muxing processes ok but after the last one it comes up with a dialog box that says "runtime error abnormal program termination". In the compile panel it says "error: can't find ac3 audio frame header". I've tried toggling with all the settings in the compile options, re-encoding the video (but not the audio) and re-installing dvd-lab but nothing has worked. I continue to get the same error message. I've included a screen cap of the compile box if that'll help and am using dvd-lab 2.23.
Sounds like the ac3 audio is corrupt.
How did you make the audio? what converter? or is it ripped from a source?
Have you tried fix the ac3 with ac3fix gui ? -
I used avi demux to rip the audio from the original file and then saved it as mpa. It's worked every other time i've done this except this time. I have no ac3 audio files in the compilation.
I've tried re-encoding the audio again in avidemux2 but with no success. I still get the same message in the compile window except now after a few seconds it automatically closes the error box that pops up and says done. When I open the finished dvd folder though I only have the movies. There are no menus, no chapter points, nothing. Only the video with the audio are in the video TS folder. I took another screen cap this time of that error box which pops up.
DVD-lab frame size
By Burig in forum Authoring (DVD)Replies: 4Last Post: 17th Oct 2011, 12:27 -
Trying to find the DVD ripper with the biggest frame size
By True Colors in forum DVD RippingReplies: 2Last Post: 18th Apr 2010, 23:01 -
Staxrip - says it can't find audio, chek my PID error - how do I correct it
By Emanef in forum DVD RippingReplies: 4Last Post: 24th Aug 2008, 13:21 -
Frame made in dvd lab pro 2
By PharmBoy in forum Authoring (DVD)Replies: 5Last Post: 28th Apr 2008, 23:57 -
dvd lab pro audio error
By tomoftenville in forum Authoring (DVD)Replies: 7Last Post: 6th Dec 2007, 17:05
