Hi,
I am new to DVD conversion. I have read various tutorials on this forum regarding converting DVD to VCD but i am unable to get a google quality at the end.
Can someone tell me how to make a good VCD. I mean converting DVD to VCD with very good quality. ?
Please i desperately need help to convert my frnds wedding DVD to VCD's
Thanks.
I used that Eazy VCD to create VCD's. To convert dvds to Xvid (as it is free) i use MagicDVDripper. I also have divx old encoder. I am ok at divx and xvid but never been successful in converting DVD to VCD.
That is rather a contradiction - VCD can't be "very good quality" due to its specifications. It's low resolution, it's low bitrate - Don't expect miracles. At the very best, old worn VHS tape quality is what you can achieve.Originally Posted by tes1234
AFAIK, EazyVCD does the DVD to VCD conversion about as good as it can be done.
/Mats -
I have a very similar question: I want to copy a DVD to VCD, but I really need to add the subtitles to the video. It's opera in german and I won't understand a word without them. I suppose I would have to integrate the subtitles into the video, but I don't have a clue about the details of how this is done. Thanks for any help.
Dr_Asik, This guide might help: https://forum.videohelp.com/viewtopic.php?p=499888#499888
And if you have specific subtitle questions, you should start your own thread in the Subtitle forum.
And welcome to our forums.
What quality were you expecting? As others have said, "high quality" and "VCD" are contradictions...
If EazyVCD did not produce results acceptable to you, then that basically means that VCD quality is too low for your tastes. So, choose another format. There are lots to choose from, with varying degrees of quality-filesize tradeoffs, and varying degrees of cross-platform/device compatibility.
powerpoint conversion to VCD
By Kratz in forum Video ConversionReplies: 2Last Post: 19th Feb 2010, 15:16 -
VCD to Divx conversion
By silverarrow in forum MacReplies: 14Last Post: 18th Feb 2010, 09:25 -
VCD to DIVX Conversion
By DarkPhoenix77 in forum MacReplies: 2Last Post: 16th Mar 2009, 13:28 -
Video is Jerky after NTSC DVD to PAL VCD Conversion.
By milindb1 in forum Video ConversionReplies: 14Last Post: 10th Sep 2008, 03:22 -
WMV to DVD or VCD Conversion
By MannyNoela in forum Video ConversionReplies: 9Last Post: 6th Feb 2008, 11:22
