I have some dvd's that I have encoded to a XviD .avi file and some of them don't have any standalone support enabled (ESS or MTK/Sigma).
I need standalone support but I'm wondering if I could enable standalone support by some easy way? Without having to rip the dvd again or completely re-encode the .avi file?
I'm on 1ghz intel pentium III so it takes really long time if I have to fully encode everything again.
Is there any magical solution or do I have to encode everything again?
Thanks in advance![]()
If they have GMC or Qpel and your dvd player doesn't support it you need to reencode.
I have a iRiver PMP-120 and I when I don't encode with standalone support the .avi file does play, I hear the audio fine but the video does appear as just green lines. I can post screenshot or record a video of my iriver playing if you would like to see how it looks?
When I enable standalone support in autoGK this doesn't happen and my video plays correctly.
So I'm pretty sure it has something to do with the standalone support :P
However I'm not completely sure about what you are talking about Baldrick, I'm not sure what GMC and Qpel is. -
They are encoding features that some players cannot handle on playback, or can only handle if implemented in a certain way.
If you have AutoGK then you may as well use it to re-encode, instead of avirecomp.
Mpeg4Modifier or the latest g-spot (2.60b) can tell you if GMC or QPel were used when encoding.Read my blog here.
ah, ok.. I get it now, thanks guns1inger
but about autogk, it's extremely slow for me. Taking many hours to re-encode a single 700mb .avi movie.
I have been using iriverter to re-encode avi files because it's working really fast for me.
However iriverter is quite buggy and has only 3 available resolutions that I can choose (320x240, 512x384, 640x480).
Since I would like my widescreen videos to have widescreen resolution, 576x304 etc. Then I can't use iriverter.
Is there any other encoder out there I can use that is as fast as iriverter (iriverter is a GUI frontend for mencoder so there must be some encoder out there that I can use)
Can my Laptop support TV Out?
By soneman in forum Software PlayingReplies: 12Last Post: 15th May 2008, 11:17 -
AVCHD support....please!
By motoxer913 in forum ffmpegX general discussionReplies: 2Last Post: 6th May 2008, 08:44 -
EyeTV Support?
By fromeout11 in forum ffmpegX general discussionReplies: 1Last Post: 7th Oct 2007, 09:37 -
Gamebridge support
By alsuse in forum LinuxReplies: 0Last Post: 17th Sep 2007, 21:12 -
SDK Support
By jain30 in forum Authoring (DVD)Replies: 3Last Post: 22nd Jun 2007, 07:50
