I got a computer hooked up to the router and three wireless. I started out with the wired one about a year and a half ago. Then added a wireless and set up a network by going through the Network Setup Wizard. No problem there. I added a second and third wireless this year and went through the wizard again and again no problems.
So now I got another that I want to hook up to the router. This one will be wired. The problem is that it refuses to go along with the program. It goes through like everything is setup right but when I check the IP, it has set its own IP number. It is not able to connect to the internets. It says it connected to the same named network as the other computers but none can see each other.
Results 1 to 9 of 9
His name was MackemX
What kind of a man are you? The guy is unconscious in a coma and you don't have the guts to kiss his girlfriend? -
I use fixed IP addresses for my computers. I set them in the router first instead of using the DHCP server in the router. That way everything stays the same, instead of the router handing out the addresses. I've had less problems setting up new computers on the network that way.
Then I just use the set address in the TCP/IP tab in the computer. I don't 'Obtain an IP Address automatically'. You need to know your DNS server addresses also, but the other computers probably have them listed. Or call your ISP. The router (Default gateway) will usually be 192.168.0.1 and the Subnet 255.255.255.0 -
there should be a release dhcp and renew dhcp in the router settings. then release renew your computers ip.
or you could just do what redwudz said ^ ^PhenII 955@3.74 - GA-790XTA-UD4 AM3 - 2x4 Corsair Vengeance@1600 - Radeon 5770 - Corsair 550VX - OCZ Agility 3 90GB WD BLACK 1TB - LiteOn 24x - Win 8 Preview - Logi G110+G500 -
The router is 192.168.1.1. It automatically assigns 192.168.1.100, 192.168.1.101 and so on. Even if I manually set the IP on this computer it will not conect to the rest of the network.
The problen is that it does not "see" the router. So I can't even go into the router's settings page from that particular computer.Originally Posted by glockjsHis name was MackemX
Remember, there's multiple settings you need to change ...Originally Posted by Conquest10
1) setting the IP of the machine (sounds like 192.168.1.99 is free)
2) set the netmask (probably 255.255.255.0 - run IPCONFIG from command prompt on another machine to check)
3) set the DNS to point to the router (192.168.1.1)
4) set the gateway to point to the router (192.168.1.1)
Then from a command prompt type IPCONFIG /FLUSHDNS
Then IPCONFIG /REGISTERDNS
Then try NSLOOKUP YAHOO.COM and see if you get back a proper IP destination address
Then PING YAHOO.COM
(if this is a private network only, replace YAHOO.COM with the name of one of the other machines) -
can you get online with this computer that has the prob by bypassing the router and directly connecting to the modem?Originally Posted by Conquest10
TJohns, after following your instructions and pinging yahoo I get:
Second time:Pinging yahoo.com (216.109.112.135) with 32 bytes of data:
Reply from 216.109.112.135: bytes=32 time=29ms TTL=48
Request timed out.
Reply from 216.109.112.135: bytes=32 time=28ms TTL=48
Request timed out.
Ping statistics for 216.109.112.135:
Packets: Sent = 4, Received = 2, Lost = 2 (50% loss),
Approximate round trip times in milli-seconds:
Minimum = 28ms, Maximum = 29ms, Average = 28ms
Going into the browser and typing in the address does nothing.Pinging yahoo.com (66.94.234.13) with 32 bytes of data:
Request timed out.
Request timed out.
Reply from 66.94.234.13: bytes=32 time=57ms TTL=49
Request timed out.
Ping statistics for 66.94.234.13:
Packets: Sent = 4, Received = 1, Lost = 3 (75% loss),
Minimum = 57ms, Maximum = 57ms, Average = 57msHis name was MackemX
Access Software from computer to Computer using network?
By Ghtpua in forum ComputerReplies: 2Last Post: 21st Apr 2010, 17:53 -
Add WAP or Wireless Router to Existing Wired Network
By theweight99 in forum ComputerReplies: 7Last Post: 28th Aug 2009, 11:25 -
Dish Network Vp211 hard drive option
By wulf109 in forum DVB / IPTVReplies: 0Last Post: 8th Dec 2008, 14:14 -
Attaching a network hard drive to my DVD player
By Zukkster in forum DVD & Blu-ray PlayersReplies: 2Last Post: 12th Oct 2008, 13:44 -
Cannot add assets over network
By JohnRH in forum SVCD2DVD & VOB2MPGReplies: 6Last Post: 3rd Dec 2007, 23:57
