I have some paper that has marked areas to create a keyring, its called pixifun and the pages are perforated to seperate easily and you can print on either A5 or 6.
Now it has little squares where the image must print and I have resized my image to 3.4cmX3.4cm (by measurement) as per the size of the squares. There are 3 (or 6 depending on A5 or 6) squares to a page and I have no idea how to print my images within these perforated squares.
There are no instructions. What program has the ability to import a photo and print it precicly using measurements on a page?
Page layout programs like Adobe InDesign, Illustrator, or even Photoshop can do the digital layout as long as you have decent measurements for where the perfs are on the page. MS Publisher should work as well. Best to start by laying down guides (lines that don't print) on your document first according to your measurements of the paper, then save this as a template in case you do more.
The other half of the equation is the printer. Many printers are known for being sloppy when feeding the paper through so if the printer is off then the measurements you took don't even matter. Most printers can be calibrated/adjusted to print pretty close to perfect, maybe up to 5mm of play when printing. To combat this keep the artwork you're printing on the tags about 3-5mm away from your guides so that it has some room to move around. Also if you're printing a background color make sure to overbleed by about the same amount, that is make the background color extend beyond the guides by 3-5mm.FB-DIMM are the real cause of global warming -
you can also use tables within Word
How to print a web page
By neomaine in forum ComputerReplies: 15Last Post: 30th Nov 2011, 23:05 -
Splitting/cutting/joining MP4 accurately...
By The.King in forum EditingReplies: 2Last Post: 2nd Nov 2011, 12:35 -
How to accurately synchronize a subtitle file with another
By scept in forum SubtitleReplies: 5Last Post: 24th Oct 2010, 07:08 -
H.264 .mov files do not accurately play. Help!
By wonderkev in forum Video ConversionReplies: 22Last Post: 4th Feb 2010, 14:01 -
How to cut ASF file accurately ?
By mahogany in forum Newbie / General discussionsReplies: 2Last Post: 3rd Jan 2010, 11:31
