Hello to all.
I demuxed a mpeg video file and loaded the audio in Adobe Audition 2. Did some tweaking to the soundtrack and now I want to use the final audio in TMPGenc to author the DVD but I haven't been able to save the Audition file in a format that is accepted by TMPGenc.
It looked as it was going to be straightforward but it isn't. The Audition file is 32/48 PCM saved as .WAV.
Any hints?
Thanks in advance.
32/48? You probably want 16-bits-per-sample, stereo, 48,000 samples/second.
Ooops!Originally Posted by bobkart
I think I've been around Hi Res files too much recently.
Thanks, bobcart!
Problem stretching AC3 audio with Adobe Audition 1.5
By Gwar in forum AudioReplies: 6Last Post: 21st Aug 2011, 08:15 -
How would I slow audio down 4% using Adobe Audition?
By Hittz in forum AudioReplies: 11Last Post: 2nd Jan 2011, 04:53 -
Audition puts audio out of synch
By blitzen in forum AudioReplies: 7Last Post: 7th May 2010, 17:52 -
Adobe Audition Mixdown- Slow audio
By tharps22 in forum AudioReplies: 0Last Post: 30th Nov 2009, 01:04 -
Convert an audio file in Audition
By didikai in forum AudioReplies: 4Last Post: 29th Jan 2008, 18:46
