I have a couple .DAT files that I want to convert to avi or mpeg to put on a dvd. How would I go about doing this? I've already tried just renaming the files to .avi or .mpg, but that didn't work.
I know alot of .DAT files are VCD files, but I'm not sure that is the case with these, as I got the .DAT files from my temporary internet files folder. They are videos that I saw online at a site (stargatesg1.com), and I want to put some of them on DVD. Here's a link to an example video: http://stargatesg1.com/MediaPlayer.aspx?contentItemId=32852&channelContentItemID=32849
Can anyone tell me how I can do this? I'd prefer to be able to use a free program.
Thanks!
Use vcdgear as suggested above (use the 'dat to mpeg' setting) to extract the mpeg video from the .dat files....
In order to put them on dvd you will need to demux the audio from the mpeg files and resample it to 48.000hz (if the dat files are infact vcd files the audio will be 44.100hz ... this is not compatitable with dvd) .... you will then need to remux the audio with the video (see tools section for apps to do both these)
Once this is done you will need to author the mpeg files for use on a dvd ... tda will do this but for a free option try guifordvdauthor (or look in the tools section for other authoring tools) -
actually one more note programs like tmpgenc dvd author can do the audio conversion for you while you make your dvd. But again its not free but does have a trial period. Fyi.
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Originally Posted by yoda313
No problem psx_pirate we are all here to lend a helping hand.
I'm pretty sure gda doesn't do it. I'd be suprised if a freeware app like that would - it's basically a author program that doesn't have a whole lot of bells and whistles. It seems to look to be a great free program but not a full robust author app. Though I must admit to only exploring the program briefly so I don't know its full potential - thats only a first impression really.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
Convert HDTV ts files to DVD mpeg or Avi
By kenmo in forum Video ConversionReplies: 5Last Post: 6th Nov 2011, 09:17 -
Can't convert files downloaded from a file hosting site
By ibzomie in forum Newbie / General discussionsReplies: 1Last Post: 30th Nov 2010, 19:27 -
convert DAT TO avi
By skorpinok in forum Video ConversionReplies: 1Last Post: 27th Nov 2010, 03:53 -
Convert TS/TS4 files to avi or mpeg
By Borg in forum Video ConversionReplies: 0Last Post: 17th Jun 2010, 20:11 -
I have downloaded file clips in .divx how can I convert to .avi?
By Ricksasha in forum Video ConversionReplies: 8Last Post: 13th Nov 2007, 13:36
