  1. If on your computer programmes just froze ie mouse pointer dose'nt move and you have to reboot every time it happens what would you say was causing this problem, a dodgy mouse or something else ?
    Regards: Patsym1
  2. sounds like a crash to me. has this been hapening for a while. if it just started to do it. it might be a program that you recently installed. check that first. second i would probably run a scandisk and defrag my drive and see if that clears it up...
  3. It has been happening for over a week now mostly with programmes like DVD2AVI, Tmpgenc, Paint Shop Pro, Video Factory, etc; I have done a scandisk and defrag still the same.
  4. have you recently installed something new??? here's another idea since its happening with your video programs. sometimes for me, if i try to open a video in ANY of my video programs that is not the correct format and completly not compatible, my pc crashs. this has happened recently with me when i changed some of my parameters for capturing....
  5. Member vhelp's Avatar
    Mar 2001
    New York
    patsym1,
    in my experience, it was my motherboard (on my 2nd pc) for a couple of weeks
    I noticed that my mouse would act very strangely, like, ie, jumpy, or fly way accros
    the screen, etc. Or, just stop working all-together! I thought it was my mouse, or
    else a software glitch. ...till my keyboard started acting up also. Then, both mouse
    AND keyboard would no longer work. Turned out it was my motherboard going on
    me - course, it was about 5 or so years old, but I had it on like, 24/7 every day
    for so many years. Anyways. . .
    So, if you can't figure it out, and/or it turns out to be your motherboard, be very
    careful of instaling a new one. You'll have to re-install windows from scratch!!
    But, you may have a software or too that is just hanging on you, locking up your
    WHOLE system, and not just your mouse. I thought I'd just share MY experience
    with ya cause it sounds so close.
    -vhelp
  6. The only programmes I have installed lately have been Dvd2Avi and Tmpgenc and these always worked before, its only since I reinstalled them I have been getting this problem of the mouse pointer and programme freezing.Although you may be right Vhelp I just put in a new Motherboard but did'nt reinstall Windows. I will try reinstalling Windows from scratch. Thanks guys.
