Scenario is having Main Concept to capture MPEG 2 and using MPEG wizard to edit the MPEG clips.
Has anyone used this combination of software on the same PC? If so have you had any conflict with the outcome of the file?
Just looking for opinions on this combination. Thanks.
I may have used the combination but had both installed without any problems.
I just did my own little test.
1 On a fresh operating system Mpeg 2 files wont play for me on WMP. Yea I know that already.
2 It appears that on a fresh operating system (XP pro) when I install MPEG wizard by itself then bring some MPEG files to edit then render out I cant play them out of windows media player.
3 On a fresh operating system installing just Main Concept encoder and I bring in mpeg 2 files or capture mpeg 2 I can play these files now in Windows media player.
It appears that MPEG wizard does not install a codec in the operating system where the encoder software will. Is it fair to say then that codecs would not interfere with each other between womble and Main Concept?
main concept's cuda encoder released to public
By deadrats in forum Video ConversionReplies: 1Last Post: 17th Oct 2010, 19:33 -
is womble mpeg dvd wizard the program i want?
By meganann in forum EditingReplies: 3Last Post: 9th Feb 2009, 00:33 -
Womble video wizard mpeg dvd
By Remyisme in forum Newbie / General discussionsReplies: 1Last Post: 18th Nov 2008, 14:47 -
Frameserving Womble Mpeg Video Wizard
By tmw in forum Video ConversionReplies: 13Last Post: 1st Nov 2008, 08:53 -
Womble MPEG Wizard - Bookmarks
By terrypin in forum EditingReplies: 0Last Post: 18th Jun 2007, 13:45
