Hi![]()
I've posted the following message on this forum, I tested the Wax but unfortunately I can't get the desired effects...
https://forum.videohelp.com/viewtopic.php?t=316328
And I don't want to use the extreme powerfull AVISynth because I'm wanting to calibrate the colors levels from my video.
Sorry if I'm becoming very boring but I'm really wanting a WSYIWYG tool.
WYSIWSYG - What You See Is What You Get (or something like a visual tool).
Let me explain what I'm wanting...
1 - You open a AVI file, this file use DivX 5.2.0 codec at 700kbs and the audio part is compressed using Lame MP3 Codec at 128 kbps, 44100 Hz, Stereo.
2 - You get something like a selection tool, like a dotted square found on many image editing softwares and this tool can be shaped to other forms, like circles, squares, rectangles, etc...
3 - You define/delimit the area using that selection tool on the entire video area. I'm wanting to make a botton horizontal bar more darker and a little bit of blue (on RGB scale), because I'm wanting to do some subtitles on the bar using another program.
4 - After you open a dialog box where you can set things like blur, emboss, sharpen, brightness, contrast, gamma, saturation (what I need)..
5 - And its's done, you set a output AVI filename, set the DivX codec and the MP3 codec, press something like a 'Process' button, wait the colored corrected video to be recompreessed. Ready!!!
I thank everbody here in advance by the full understanding of what I'm wanting...![]()
My sincere thanks and my sincere sorries...
See Ya!!! Mates
(australian english even I'm a brazilian and speaking natively portuguese)8)
Closed Thread
Continue in your first topic
Just reply to add new information. You can also edit the subject in the first post if you want a new better subject.
color correction in MeGUI
By codemaster in forum DVD RippingReplies: 1Last Post: 2nd Mar 2012, 20:56 -
mpg2 color correction?
By Mike99 in forum RestorationReplies: 74Last Post: 25th Oct 2011, 22:31 -
Increasing color depth and sampling for color correction
By poisondeathray in forum Newbie / General discussionsReplies: 17Last Post: 17th Oct 2009, 09:06 -
Color Correction for DV
By bsuska in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 16Last Post: 23rd Oct 2008, 17:24 -
Color correction issues.
By ziggy1971 in forum Newbie / General discussionsReplies: 0Last Post: 17th Jan 2008, 22:17
