Hello
This is the first time I use VirtualDubMod, the version is 1.5.10.
I have an AVI file, its size is almost 700 MB. I have an SRT file, it is the subtitle for the first file.
I want to merge them together so I will get one AVI file.
That's exactly what I did after reading this guide How to add permanent subtitle to a video with virtualdubmod
The problem is that I got an AVI file which its size is 778 MB. So unfortunately I can't burn it on one CD.
The question is
How can I save the file in the AVI format with less space (between 650 and 700 MB) using VirtualDubMod?
You must set the video bitrate to get correct file size, see https://forum.videohelp.com/viewtopic.php?t=316373&highlight=
You could also use avirecomp instead of virtualdub to add the subtitle. Easier to use and very easy to set the output file size. -
Thank you, that was exactly what I was looking for
But the result's quality is worse than the original video. Can I fix that ? -
No, you will lose some video quality if you add permanent subtitles. You can use higher bitrate but it means bigger file size then.
Saving file question
By jyeh74 in forum ComputerReplies: 4Last Post: 14th May 2011, 20:41 -
Please hrlp with chaniging VOB file to AVI (with saving recorded scenes)
By Kiplox in forum Newbie / General discussionsReplies: 1Last Post: 9th Mar 2011, 05:38 -
Deinterlacing MiniDV AVI file and saving as lossless AVI
By Dave2ic in forum Video ConversionReplies: 3Last Post: 27th Dec 2010, 15:11 -
Video is huge after saving in virtualdubmod.
By rosbif08 in forum Newbie / General discussionsReplies: 7Last Post: 7th Aug 2008, 16:01 -
AVI in VirtualDubMod video quality question.
By scott274 in forum Newbie / General discussionsReplies: 17Last Post: 20th Jul 2008, 23:23
