I have an .avi file that when I play it I get a fairly fast (3 second) green blank screen. when I ask QT for the info format it says:
, 512 x 384, millions MPEG layer 3 22.050 kHz
it plays in MPlayer OS X
why is that? can it be converted somehow?
cheers and thanks
Results 1 to 10 of 10
MPro 2.66 3GB RAM 1.5TB HD's
MigliaMiniHD
QTPro, MPEG2 add on MPlayerX2
MPEG Streamclip
24 + 21" samsung flat panels
G4dual 2GB
AlchemyDVR card -
If it plays in Mplayer, can you give us some more details about it ? Put the file in mplayer playlist, highlight it, and call the "window info" through the "window" menu (or hit command-i).Originally Posted by rotutsJean-Philippe Schuck
Un générique, un autre jour, le blog sur les génériques de dessins animés -
MPlayer says this:
video format:
05XD, 1246.8 kbps 512 x 384 25 fps
audio mp3 56 kbps 22 kHz stere0
Lenth 6 seconds
the file is longer than 6 secs
VLC player also plays it ( the new version, dumped the older one):
stream 0: codec DX50
Stream2: codex mpga
I have another file from the same souce and it says the same thing in MPlayer and plays fine in QT. in VLC it says nothing ( the second file)
is this just some sort of corruption?
thanks for any helpMPro 2.66 3GB RAM 1.5TB HD's
MigliaMiniHD
MPEG Streamclip
G4dual 2GB
AlchemyDVR card -
thanks Ive downloaded avidemux 2.3.0 its in a folder with lots of compoments but its unclear how to install it.
I had downloaded it from another link and got the icon but it did not work with the intel machine
any ideas on how to install it from the folder components?
thanks againMPro 2.66 3GB RAM 1.5TB HD's
MigliaMiniHD
MPEG Streamclip
G4dual 2GB
AlchemyDVR card -
First you should install x11 from your MacOS X install DVD (x11 is not installed by default). Then, as you say you got lots of components in a folder instead of a single package in a disk image, I assume that you haven't downloaded the correct file. You should download avidemux for Mac OS X 2.3 preview (bottom of the page) which is universal binary.Originally Posted by rotutsJean-Philippe Schuck
why not just install Perian, and THEN see how QT handles the file?
or have you tried this already?
I've gotten older files that would not play correctly to play
nice after installing Perian.
If after installing Perian and the file doesn't play, then
I'd reccomend D-Vision or ffmpegx to change/recreate the file."Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User -
Just a couple of suggestions to see how they might work for you:
1. DivX Doctor the file.
-or-
2. Duplicate your QT Player, set it to run in Rosetta, and see if the file plays there (pre- or post-Divx Doctor'ing). -
KillerThanks for the link to Perian
that seems to have fixed my green screen!
to bad I just got around to installing it today!
cheersMPro 2.66 3GB RAM 1.5TB HD's
MigliaMiniHD
MPEG Streamclip
G4dual 2GB
AlchemyDVR card -
aaah...rotus....
u r welcome my friend."Everyone has to learn, so that they can one day teach."
Urban Mac User
Green pixels all over - HELP
By ski in forum Newbie / General discussionsReplies: 3Last Post: 4th Jan 2011, 15:04 -
converted AVI to DVD, VIDEO_TS is created, but once on DVD, movie is green
By jens.3 in forum ffmpegX general discussionReplies: 3Last Post: 18th Dec 2009, 01:43 -
Could I use a green fabric as a green screen? Where could I get fabric?
By bojadada in forum Off topicReplies: 2Last Post: 5th Dec 2009, 12:48 -
Latest Flash Player Beta Blue Screened My Machine
By Soopafresh in forum ComputerReplies: 3Last Post: 27th Nov 2009, 20:38 -
green picture!
By w50cfc in forum DVD & Blu-ray PlayersReplies: 2Last Post: 25th Jun 2007, 03:39
