Hi!
I'm new here and i would like to know if there's a way to copy the movie "The DaVinci Code". It's a sony dvd and i' ve tried with dvd decrypter, dvdfab and anydvd without any result!
I would be glad if anyone could help me!
Welcome to the forum, takiant!
To make your experience as pleasant as possible, may I suggest you take the time to read the rules/AUP.
Do not hijack topics.
Please try to stick to the author's first post in each topic, if you want to discuss something else, create a new topic.
/Mats -
RipIt4Me utilizes DVDDecrypter and FixVTS automatically. It's supposed to handle new copy protection better than the older apps DVDShrink and DVDDecrypter alone I have it installed but haven't tried it yet.
Hi there,
I initially had the same problem but managed to get round it doing the following:-
1) Have AnyDVD running
2) Use DVD Decrypter to rip the dvd to the Harddrive in " FILE MODE "" (you will notice that not all files are copied - don't panic this is normal as far as I can see its the dodgy files that house the Sony protection and are not necessary to be copied over)
3) Once ripped in file mode start up a program called " FixVTS " (latest version is 1.6 i believe but use the latest to be on the safe side) and process the dvd through this program from the ripped copy on your harddrive. This program basically converts the dodgy VTS Files so that programs like " DVD Shrink " can read them correctly. Once the program (FixVTS) has completed this task you will have a version of the dvd (stipulated in the location that you chose for FixVTS to do its work) that DVD Shrink will quite happily process without any errors.
Failing that download the latest version of AnyDVD as I have found that it now works better on new forms of the Sony Protection and is more compatable with programs like DVD Shrink.
Wish you luck.
testing thecoalman's suggestion of [code=php] test [/code] ... FAILED!
By vhelp in forum TestReplies: 1Last Post: 10th Jun 2009, 01:15 -
how can i find the region code of a backup and if its ntsc/pal
By korazy in forum DVD RippingReplies: 4Last Post: 26th Dec 2008, 22:10 -
Need code for pioneeer bdp lx70 code for multi region ...
By SHERWOODSelectrical in forum DVD & Blu-ray PlayersReplies: 2Last Post: 21st Nov 2008, 12:42 -
PHP code used to generate code for Avysinth join mov and avi files
By lindylex in forum User guidesReplies: 0Last Post: 19th Sep 2008, 03:37
