I want to make some some dvds but i dont want to encode them with a 2 channel wav file. Is there a program that can encode to ac3 or something?
CCE does not encode to DD5.1
There's a proggy called "Sonic Foundry Soft Encode 1.0" that can do it.
Regards.
Michael Tam
w: Morsels of Evidence -
Has anyone seen Soft Encode for sale?. It isn't even on Sonic Foundry's website anymore.
they have diconntinued the the making of Sonic Foundry Soft Encode 1.0
but if you look hard enough you might find it...and by the way VCDs dont not support DD 5.1 -
Does anyone know if the other formats like SVCD or XSVCD can play DD5.1 ?
/Pete -
Neither VCD nor SVCD supports DD5.1
You could do whatever you want with one of the X-variants (as they are simply non-standard S/VCDs) but it is highly unlikely that any X/S/VCD with DD5.1 audio will actually play as intended on a stand-alone player.
Regards.Michael Tam
By the way, it appears that Pioneer DVD players won't play DD-encoded CDs anyway. None of my Pioneer players recognize the DD stream...
vcddude
Dolby Pro Logic IIx encoder
By nateo200 in forum MacReplies: 4Last Post: 4th Feb 2012, 13:45 -
Dolby Pro Logic vs Dolby Digital?
By therock003 in forum AudioReplies: 17Last Post: 11th Jun 2011, 19:51 -
From Dolby Digital AC3 to Dolby Digital Stereo and back
By moviebuff2 in forum Newbie / General discussionsReplies: 2Last Post: 23rd Dec 2007, 19:54 -
How to downconvert Dolby Digital to Dolby Pro Logic II?
By randyharris in forum ffmpegX general discussionReplies: 0Last Post: 2nd Nov 2007, 16:54 -
Dolby Digital Surround EX encoder
By grasswhopper in forum AudioReplies: 1Last Post: 17th Aug 2007, 23:49
