i have an mpeg file ,if i watch it on any number of programmes it plays perfectly well and in sync,however ever time i use TMPGEnc DVD author to make a dvd of this file the audio goes out of synch around 9 mins into the file.
I had made hundreds of DVDs this way and never encountered this problem before..
Any suggestions would be most welcomed
The mpeg is probably "broken" even if it's playable.
Try repair/fix the mpeg file with videoredo -> quickstream fix.
Or use projectx or pvastrumento and fix it by demultiplexing it to video and audio files and then import they in TDA. -
i did the quickstream fix with video redo...it only took 10 seconds...and produced a 4kb sized file does that sound correct?
Strange Audio Problem
By Wanderlustus in forum ComputerReplies: 4Last Post: 21st Feb 2011, 15:27 -
Strange MKV audio problem
By Captain315 in forum Media Center PC / MediaCentersReplies: 0Last Post: 21st Dec 2010, 23:00 -
Strange audio glitch when converting from avi to mpeg for DVD.
By silmarallion in forum Video ConversionReplies: 3Last Post: 6th Nov 2009, 09:24 -
Strange problem between AVI(mpeg) file and DVD based on AVI(mpeg) file
By 1234567 in forum DVD RippingReplies: 49Last Post: 15th Feb 2009, 08:36 -
Strange Audio Sync Problem
By innovyse in forum Video ConversionReplies: 2Last Post: 6th Dec 2007, 14:36
