maybe one of you audio experts can help me, im trying to burn a flac cd
and with every album i try to do so, loading my cue shit in eac; i recieve this:
it happens with every flac album i try, what is the deal?
It says it can't find the file in line 7.
That specifies a relative (to the cue sheet) path, with a folder "Dre Dog", which in turn has a folder "The New Jim Jones", and the actual files in that sub-sub folder.
Is that what you have?
If not, either create the folders mentioned, or edit the cue sheet to match your actual file layout. -
It isnt in the folders stated i tried making 2 seperate folders/names following the above and it didnt work. i also tried a different album from how you say, "Mac Dre & Mac Mall" and in another folder "Da U.S Open" judging from the cues info and its the same thing?
the line 7 error
http://www.hostimage.org/img/714298.png -
I'm guessing here, but I think the file paths are relative to the cue file.Originally Posted by willhenderson
If the cue is in the same folder as the audio files, delete the folder refs in it (use search and replace); eg:
i.e. search for
FILE "Dre Dog\The New Jim Jones\
replace with
FILE " -
ive had it, i cant do it.
ive got nero a pretty recent version although there isnt support for flac - does anyone know of some type of plugin i can get? so that way i can burn flac files as i would mp3s and have the program do the convert to wav for me -
here is a plugin for nero, it supports a lot of things,
didnt try it myself but i heard it lets you burn flac files.
here is the link :
http://www.cole2k.net/?display=NPI
another option is to use foobar to convert to wav and then burn the files.
good luck.HELL AINT A BAD PLACE TO BE
Some possible problems I'm Having with EAC . . .
By Seeker47 in forum AudioReplies: 4Last Post: 6th Dec 2011, 10:47 -
EAC + lame.exe: sometimes there is 32 kBit/s, sometimes not in command line
By flashandpan007 in forum AudioReplies: 5Last Post: 13th May 2011, 11:36 -
EAC tutorial
By kippard in forum AudioReplies: 4Last Post: 25th May 2008, 03:06 -
FLAC, should i use this?
By SE14man in forum Newbie / General discussionsReplies: 23Last Post: 7th Aug 2007, 09:17 -
Does EAC remove Copy Protection from CDs ?
By Seeker47 in forum AudioReplies: 4Last Post: 15th Jun 2007, 18:49
