On dvds that ive burned with dvd decrypter i cant get any sound out of computer. works fine in dvd player, can get sound for system sounds out of speakers. if i open disc with dvd shrink and play with dvd shrink works fine. dont know if its a problem with computer or media. thanks in advance for help.
windows media player,sonic player, media center,cineplayer, all have same resuslt. sorry should have stated that.
No audio at all from dvds, not sure what ac3 is. Sorry youre dealing with a rookie here, thanks for your patience and help. Agian, if I use dvd shrink to open the disk and then use dvd shrink to play, works fine. Just other software, no sound. Ill take your advice on the other issue as well, and just buy some better disks and use Imgburn. Thanks again.
What is the best virtual surround sound from a motherboard or a sound-card?
By MarcMiller in forum ComputerReplies: 0Last Post: 19th Jan 2012, 22:03 -
3d video with dts sound how to convert to ac3 sound
By fredddiemercury in forum Video ConversionReplies: 4Last Post: 2nd Nov 2011, 15:54 -
Audio Sound File Saved - Canot Hear Sound - Total Recorder
By Teac23 in forum ComputerReplies: 1Last Post: 15th Apr 2011, 15:29 -
Need advice getting rid of buzz sound at end of every word of video sound
By OM2 in forum AudioReplies: 18Last Post: 30th Oct 2010, 12:58 -
DVD LAB : Different sound in different movie (MIXED SOUND): NOT WORKING?
By SteamrollerLive in forum Authoring (DVD)Replies: 2Last Post: 24th Jun 2007, 19:01
