  1. Member Yansky's Avatar
    Jun 2006
    Australia
    Hi, I'm having some problems converting an xvid avi file to a dvd compliant mpeg-2 file using ffmpeg.
    The problem I'm having is that ffmpeg isn't using the bitrate I specify. I've tried
    ffmpeg -i video.avi -vcodec mpeg2video -acodec mp2 -b 7000k output.mpg
    but the bitrate hovers at around 2500K when it's converting.
    I also tried
    ffmpeg -i video.avi -sameq -target dvd output.mpg
    but the bitrate hovers at around 6500K when it's converting. Which isn't the same bitrate as the original video.
    Anybody know why it's doing this?
    Feb 2004
    Australia
    https://www.videohelp.com/tools?tool=gui4ffmpeg
    Up above there is "options" ... uncheck preset , unlocks to generator down below
  3. Member Yansky's Avatar
    Jun 2006
    Australia
    Thanks, but gui4ffmpeg is also not using the bitrate I specify. As you can see from the screenshot, the bitrate is around 4680kbits/s, not 6000kbits/s - which is what I specified.
  4. Member GTRBudda's Avatar
    Jul 2005
    I believe what you're seeing is because the output mpeg is VBR and the numbers are what's going on at that moment during the encode. The -b is average bitrate but moment by moment the actual can move around quite a bit. If it's any help, this is a script I use fairly often. The padding is to beat overscan:
    "C:\Program Files\ffmpeg.exe" -i "C:\path\to\file.avi" -target ntsc-dvd -b 6500 -maxrate 8000 -aspect 4:3 -s 656x448 -g 15 -padright 32 -padleft 32 -padtop 16 -padbottom 16 -acodec ac3 -ab 192 -ac 2 -mbd 2 -qmin 2 -async 1 -y "C:\path\to\file.mpg"
