Hi,
I am trying to create one DVD of the two DVD disks. Both are two parts of the same NTSC DVD movie - Amadeus.
I ripped everything off and left just VOBs from the two discs and created two DVDs with no menus; extra languages, ets. After that, I tried to join the two DVDs as one track with TDA and it looks like everything was going fine.
But when I used "Stimulation" I saw a "Warner Brothers" label at the very beginning of the second DVD (between the DVDs). I definitely would like to remove the lable as I am trying to create a movie just on one DVD disc without any interruptions like the label.
I believe I should create a new DVD from the second DVD using DGMPDIndex. But once I inserted all three VOBs of the second DVD into DGMPDIndex and opened the movie for preview, I could not see the label. If I click Preview or Play, the movie in DGMPDIndex starts playing without "Warner Brothers".
How can I find and remove the damn label? Thank you!
Try VOBBlanker (free) or DVDRemake Pro (not expensive).
There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
Originally Posted by vertical
You could use Nero Recode, as well. Use the option "Remake a DVD" or "Compile a DVD".
Just import main movies into a program and use "Start-End" to exclude that WB from the beginning of the second part.
How to remove annoying "Press Esc to ..." message in Flash Video
By roma_turok in forum User guidesReplies: 517Last Post: 23rd Oct 2017, 10:09 -
Restoring "Safe To Remove Hardware" Popup Confirmation
By CobraPilot in forum ComputerReplies: 8Last Post: 3rd Jan 2012, 12:35 -
DVD with menus, replacing "bad" video with "good" video
By chipsndukes in forum Authoring (DVD)Replies: 34Last Post: 4th Dec 2008, 17:45 -
is it safe to remove "analyze" files from DVD Shrink?
By Bamahusker in forum Newbie / General discussionsReplies: 2Last Post: 12th Jul 2007, 14:18 -
question about how to remove this software, "wmfdist95.exe" WMA
By jimdagys in forum ComputerReplies: 2Last Post: 15th May 2007, 04:07
